Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
Both cameras are black and flashlight doesn't work
Hi everyone,
I recently replaced my iPhone 5s battery. Everything worked well except for both cameras and flashlight. Camera app is not taking pictures and the screen is always black. The flashlight doesn't light at all, the button comes unchecked as soon as I push it. I reopened the case and checked all the connectors, did a complete reset, tried to use the old battery but nothing changed. I can't explain why this problem could happen on both cameras, nothing seems to be loose or broken. Maybe there is a problem on the logic board? Thanks
Score 6
3 Comments
if you are having problem on iphone camera and its not working then its very irritating if you want to solve your problem regarding to iphone camera then solve this reading this article
https://iphonenotworking.com/iphone-came...
by
Hello all, my problem was resolved simply by deleting a lot of photos and videos! As soon as I did that, both my camera and flashlight began working again.
by
this worked thank you so much!
by
Add a comment
Chosen Solution
There are a few things that can cause this issue. I would first try a hard reset...holding the power and home button for 10 seconds or so. If that doesnt work, try to Go to "Settings" > "General" > "Reset" > "Reset All Settings". This won't delete any files or apps on your iPhone but erase your preferred settings on the apps. After the resetting, open the camera app and see if it works okay now.
If not: Go to "Settings" > "General" > "Reset" and choose "Erase All Content and Settings". This will delete all files and third-party apps on your iPhone so it should be the last resort. To not lose any data, back up your iPhone before factory reset (If important photos are lost after factory reset, recover iPhone/iPad photos with iCloud/iTunes backup).
If none of those work, check the Filters near the Flex connection on the logic board to see if they have continuity or have been damaged or knocked off the board.
Before doing the factory reset, I would definitely check the filters first but never hurts to have a full backup of your phone either way.
Score 4
4 Comments:
I already tried every possibile reset. I will check the filters like you said, do you have any image of the location of camera filters? Thanks
by
Hmmm...
The only common denominator between those three is the CPU. Let's put that aside for now as it seems unlikely to be the problem.
I would check the voltage on the PP2V85_CAM_AVDD rail. It drives both cameras and the RCAM also sends an enable signal to the Strobe circuit (RCAM_TO_LEDDRV_STROBE_EN). In theory, if 2V85 is bad, then both cameras stop working and the enable signal to the Flash is missing, hence no flashlight.
by
hostlikepro - That does NOT work
by
Let your phone die fully and then let it turn on itself by charging.
by
Add a comment
First of all, i have had this problem over two phones and it is really frustrating.
The problem is that both cameras will not work and stay black or just open the app itself. The flash is also ruined and cannot be turned on. Evertime i try to use the flash a message saying that it is in use by another app come up. I had this problem on my samsung galaxy s7 and now on my new samsung galaxy s20 FE. This is a very concerning problem to me and i would appreciate any help.
Score 1
Add a comment
I had the same issue with my iphone 8. The camera and the Flashlight just would not work i tried every reset and nothing. when in reality all you ahve to do is delete a lot of photos and videos combined, i had over a thousand and i deleted around 500 photos and videos all together then powered off the phone turned it back on, opened snapchat and boom my camera finally worked.
2 Comments:
On your phone picture or snapchat pictures cuz I’ve deleted over 1000 pictures and still don’t work
by
I noticed that my back camera,front camera and flashlight stops working
So I opened my phone and removed back camera
Then the front camera starts working
But my flashlight isn't working
If I try putting back the back camera both camera and flashlight won't work
So I removed the back camera and the front camera starts working back
My question is that
Is it the back camera that won't allow both flashlight or front camera to work
Or does it mean my back camera is damaged and can replacement of it make both the front camera and flashlight to work
Please I need answers
Thank you
by
Add a comment
If I drop my iPhone XS and the camera is not working and the Flash light
Add a comment
Add your answer
Francesco will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 63
All Time: 129,590
