Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Showing apple logo and turning off
Hi,
I've googled this all I can.
I have an iPhone 6 that I wiped via 3uTools
I'm now been stuck where it only shows the apple logo then turns off again. I've tried the home button and power button and different USB cables. I've tried a new battery and new charging port and still no avail.
The phone isnt recognized with iTunes or 3uTools.
What else can I do? Its not iCloud unlocked so Apple wont have it, Plus its had third party repairs too.
Add a comment
1 Answer
Chosen Solution
Hi Jaymie. Is this the same phone as the one in this question (Phone doesn't turn on, shows apple icon)?
If it is, then unfortunately, the answer remains the same. This phone will require some micro-soldering repairs. These are my typical recommendations for boot-looping devices but I believe you've already tried some or most, if not all of them:
  • Try a hard reset (Home & Power button for 10 secs)
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Try to connect it to different computers (mac/pc if possible) with an updated iTunes
  • Put the phone in recovery mode (search DFU Mode). Careful, this can reset your data
  • Use 3uTools for putting it in and out of Recovery Mode
  • Use 3uTools to flash the firmware (you can't downgrade)
  • Check the condition of all the flexes (with magnification)
  • Disconnect the Front Camera Ribbon from the logic board and reboot your phone
  • Disconnect the screen assembly completely and see if iTunes will recognize the phone.
Are you getting any error messages from iTunes?
Mise à jour (17/09/2017)
Hi,
I'll give these another bash. The phone was working before just didnt recognize the passcode so reset the phone.
There is no notifications on Windows or iTunes
Score 1
Add a comment
Add your answer
Jaymie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 146
