Water damage any change to revive?
Friends,
Please tell me whether I should give up or not. Story:
My 6S has seen a washing machine from inside. 1 hour later he was clean and smelled good but didn't turn on anymore. Removed the screen and I dried it, I put him in a bag of rice for 24h.
No sign of life so I bought a new one. A month or so later he still didn't turn on but I read it's a good idea to lay him in a bath of alcohol 96% for 10min and let it dry. No luck. - I did remove the battery first.
Another month later, I gave him a bath in a descaling fluid used to clean espresso machines. In order to remove excess chalk. I gave it another bath in alcohol. Of course without battery and screen. No luck.
Then I realized I can try to charge the battery using another iPhone 6s. The OK iPhone turned on and charged the battery, but stopped charging at 14%. Yet, it did power on without cable.
I put back the battery in the dead iPhone (knowing it was at least 14%) but still no luck. It doesn't turn on.
I assume that, since the battery is directly connected to the logic-board, that the logic board has died. Therefor it would be nonsens to buy a new dock-connector. Please confirm.
Even though the battery doesn't charge, it still has a minimal 14% - so it should be enough to boot up the dead phone. Buying a new battery is therefor also not needed.
And oh, I tested the screen and it works (with some water damage marks). So that's not the issue.
Please advise me what else I can try, or if I should trash the 6S.
/w.t.f. .... it is recognized by iTunes when in DFU mode.
2 Comments
Aviv Goldstein besides all the great points @refectio makes I would at least try it with the battery from another 6S and see what you get. Just because your battery said it was at 14% does not mean it is. The battery is water damaged and most probably lying
by oldturkey03
The iPhone was shortly recognized by iTunes while in dfu-mode. I tried to restore it but it kept on "waiting for iPhone".
Does this mean that the dock-connector is 100% fine?
by Aviv Goldstein
