Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
539 Questions View all
no charging, no wake up after a dead battery change battery
Hello,
I bought a dead Macbook pro with battery in bad condition, the battery was inflated.
I bought a new battery from Ifixit :) thinking I was on the good way.
I replaced it and then .... nothing !
current status is :
the battery is half charged
the battery indicator works fine
the Macbook don't start :
with the battery
with the charger with or without battery
the magsafe stay green (try with another...same result)
I have tried SMC.... no result.
I can change any components or make any tests necessary, but I don't have the schematic or board.
Please help me, thank you.
Greg
Add a comment
1 Answer
Chosen Solution
How does the logic board look any corrosion or wet stains? You'll want to pull it and look at the other side. Review this IFIXIT guide: MacBook Pro 15" Unibody Mid 2010 Logic Board Replacement.
Use a piece of electricians tape to help you ease out & then back in the ribbon cables by creating a pull tab.
Take your time & make sure you don't force things!
Reference these images to help you compare things:
Don't pop the heat sink at this time!
Update (09/18/2017)
Review your connections as you may have not fully inserted the ribbon cables into the clamps.
I would also recommend you get a USB keyboard & mouse as you may need to use them if the keyboard & trackpad is damaged which is what I'm suspecting. You'll need to use the Power Pads located on the logic board to turn the system on with the keyboard & trackpad cables disconnected.
Score 1
Comments:
Hello,
thanks for answering my question.
Well the board is allready out of the Mac and there is no corrosion.
the board has no burn component.
Looking forward...
Greg
by
Add a comment
Add your answer
Grégory Greuzat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 69
