Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3252 Questions View all
Speaker enclosure has cracked, distorted sound.
A friend of mine dropped his iPhone 4 and shattered the screen. Also, the ringer speaker has a cracked, distorted sound. Thanks to ifixit, I successfully replaced the screen and speaker enclosure, but the speaker quality has no improvement. The speaker has now been replaced twice and still isn't fixed. Any idea what else could be causing the problem?
Comments:
One of my friends has an iPhone 4 and was experiencing issues with sound quality coming from the speaker. One day it was terrible and a couple days later it was fine.
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
just happened today to me on a 3gs. it turned out that the case was blocking the airflow of the sound causing the sound to be distorted. try cleaning off the speaker screen on the case, also remove anything that could be blocking the speaker port (in my case it was a little bit of rubber that had been and was covering up the speaker port. hope this helps
Add a comment
Mine just started getting worse and worse. If I remove the battery for a bit or power off for a while it will come back but still sound distorted. And then fade over the next couple days to barely audible. Anyone know of a fix? I replaced the speaker and dock connector and no help. (loud speaker connects to the flex of the dock connector so I thought it ight be broken)
Add a comment
Add your answer
hyproglo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 3,824
