The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
36 Questions View all
Why don't I have spark
Have changed plugs, plug wires, crankshaft sensor, camshaft sensor, coil pack, ignition module, and checked the neutral safety switch. Still have no fire. Why?
Score 1
Comments:
@hostile contact me by email if you need the SM for your Neon.
by
Add a comment
1 Answer
Chosen Solution
@hostile this will be difficult since you've already changed the most common faults. Check the voltage to the coil pack and you should get 12V on the center wire and 12.27V - 12.63V on wires 1 & 3 when cranking. Also check the voltage at the cam and crank sensors which should show 0.03-6.34V. Right now it appears as if you are having issues with the PCM.
Comments:
Yeah, that's my very next buy. Was pricing it 2day.
by
Add a comment
Add your answer
Joseph Turner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 40
