Why don't I have spark
Have changed plugs, plug wires, crankshaft sensor, camshaft sensor, coil pack, ignition module, and checked the neutral safety switch. Still have no fire. Why?
@hostile this will be difficult since you've already changed the most common faults. Check the voltage to the coil pack and you should get 12V on the center wire and 12.27V - 12.63V on wires 1 & 3 when cranking. Also check the voltage at the cam and crank sensors which should show 0.03-6.34V. Right now it appears as if you are having issues with the PCM.
Yeah, that's my very next buy. Was pricing it 2day.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 190
1 Comment
@hostile contact me by email if you need the SM for your Neon.
by oldturkey03
