Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
385 Questions View all
It won't turn on
It won't turn on no power at all it was working but now it's not
2 Comments:
Power from outlet?
by
Does it have bugs in it?
by
Add a comment
1 Answer
To troubleshoot this problem :
Plug something else into the same outlet. If it doesn't work, than it's a problem with that outlet.
It could also be a problem with the power chord. Make sure it's connected correctly. If you can, try to use a different one.
Check the connectors on the power chord and the outlet on the PS4 itself for sign she of damage.
If none of these work, it's probably a problem with the power supply. These are quite common, but you're probably have to take it in to a repair place.
I personally sent mine in to TronicsFix and I would highly recommend them if you decide to send it in. If not, there are various guides in the internet to replace the power supply yourself.
Add a comment
Add your answer
Denzel Alrxander will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 208
