Unibody MacBook Pro models with 13" displays produced from 2009-2012.
4628 Questions View all
Won't turn on after sleep sensor/battery indicator tore
I was replacing the charging port on my macbook pro. When putting everything back together the sleep sensor/battery indicator got stuck and when I tried to get it out it tore. I'm kicking myself for not going slower on this, but now the computer will not turn on at all. Is there a way to replace this ribbon? Please help.
1 Comment
Exactly which MacBook Pro are we talking about here?"
by
Add a comment
1 Answer
Chosen Solution
The MacBook should still turn on without the battery indicator plugged in; why did you replace the charging port and was it working properly before?
If it's a Core 2 Duo model, make sure the keyboard is connected properly, otherwise the power button will not be recognised. i5/i7 models will boot automatically when the charger is plugged in, if the battery is disconnected or newly reconnected.
Score 2
Add a comment
Add your answer
goldenroses will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 135
