Gear iconx replacement battery
I have a brand new set of Samsung Gear IconX Headphones and the left earbud has a battery life somewhere around 15-30 minutes. The right runs as per the specs. I don't have a proof of purchase, so even though they are new and still within the warranty period, I can't send them to Samsung for repair or replacement and Samsung does not sell the battery.
I've been looking, unsuccessfully, for a replacement battery, so I could try to swap out the battery myself.
Does anyone know where to get a replacement battery?
Has anyone successfully done the repair?
Thanks.
Update (09/12/2017)
So, I went ahead and opened up the left earbud and it actually was surprisingly easy. The battery in it is a "Varta Cp1254 A2". It is a 50mah version, but Varta makes an "A3" version that is identical except that it is 60mah, so that seems like a logical upgrade. The only problem so far is that these batteries are pretty difficult to find without ordering in bulk from China. While I would definitely like to find 4 A3's, I have no use or budget for a minimum order of 1000. If anyone has any or can hook me up with a vendor, I'd definitely be interested in buying at least 4 of them. Thanks.
9 Comments
How did you open the earbud
by Daniel Adame
Anybody figure out how to open the earbuds yet? I have the same issue, only with the right earbud instead of the left.
by Wade Cheek
Hi mate! Could you please tell me how to open it? Do you used special tool or something? I need to replace the battery of mine. I found a supplier which is like £7.00+ each if buying 5pcs. Thanks!
by Rommel
hi rommel,
do you have any spare to sell? i need 2pcs since it hard to get in my country
by Muhammad Talhar Samsudin
There is no official step-by-step on opening the earbud to replace the battery. Nevertheless, I found the following CN website providing detailed disassemble steps for IconX SM-R150
Hope it helps
http://www.52audio.com/archives/6905.htm...
by Sau Koon Neo
Show 4 more comments
