Glitch after Screen Replacement.
So i had dropped my phone and it smashed the screen, I had bought a new screen and replaced it at home with my husband ( we are pretty well versed in this ) everything went FLAWLESS - camera work, 3d touch, touch ID, exc everything was fine.....then for some reason ONLY when i open apps the bottom of the screen doesn't react correctly....if I'm on home screen its fine i can touch the apps just fine on the bottom...once i get in an app anything on the very bottom doesn't react correctly ...( example: in Facebook the bar at the bottom if i touch notifications it will just open the bottom part of the feed showing )
1. I've established that the bottom part of the screen DOES work
2. Doesn't seem to be software related I've reset and restored
3. I opened back up and checked the connectors
At one point it went back to full function for about 30 minutes and then stopped again ...It doesn't add up to being a faulty digitizer ...ive read cleaning the connectors with alcohol helps....has anyone come across this.
