Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
doesn't charge , used different charge port , still same problem
Hello
the phone is not charging
i just want to ask how to verify if the cable is connected and charging ? before assuming that its an ic problem
also i want to ask , i checked the battery voltage and it was 4.36 , is it because of the high battery voltage that the phone is not charging ?
another ting is , i saw a video for charging troubleshooting , he put the terminals of the voltmeter , -ve in the metals covering motherboard , +ve in the dot just under the battery port ( while battery plugged in ) to check the battery raising or lowering in charge , i did it , i saw a spark, then when i try to measure battery voltage , it's 0 volt , what happened ? i tried to turn on the phone by power supply and it works thank god , but what happened to the battery ? it's still at 0 voltage
thank you in advance
Add a comment
1 Answer
Chosen Solution
Battery is probably short circuited (You have probably burnt out the gas gauge board / or the battery itself located at the bottom of the battery) and the battery will need to be replaced.
In the future I would strongly not recommend shorting terminals unless you know what you are doing. Better than having a paperweight phone.
Score 4
3 Comments:
thanks
i will not try that again
but i want to ask you is the reason that the phone not charging was the high battery voltage at the beginning ?(4.3)
by
and also how to check if the cable is charging please ?
by
help me guys
by
Add a comment
Add your answer
Hesham Adwan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 69
