Repair information and support for the Acer Aspire E15 laptop, released from Acer in 2015. Model number: E5-575-33BM.
82 Questions View all
How do I fix my right hinge: no longer attached to screen?
The lower right hinge is no longer attached to the screen. Every time I open my laptop it pops out of place, and I must push it back in, but it still remains loose and will pop back out anytime. I removed the frame of the screen and discovered that the hinge is attached to the screen by two means: screwed into glue (wtf? really?) and a metal column spanning from the top right corner (screwed in) to the hinge itself (used metal "hammer," can't simply unscrew and replace: again wtf?). I believe this is a simple repair job I can do myself but I need the parts. Where could I get those? I don't want to send it into a repair shop that will charge me 100+ for something so simple to fix. Thank you.
Update (09/10/2017)
Here are 3 images. Notice, the metal rod is snapped at the lower right corner that would normally stabilize the screen. Also, the hinge itself is no longer connected, as it was only glued to the screen.
Score 1
1 Comment:
Could you please take a picture and attach it to the post?
by
Add a comment
1 Answer
Does the hinge itself still move? It's just broken to where the hinge attaches to the laptop right? If so use JB weld. You can get that at the hardware store.
2 Comments:
Yes the hing still moves. I purchased the JB weld from walmart. I'm afraid that the glue will be an issue long term if it is not a permanent solution. Will the glue come off? Also, will it affect the wires that run near that area?
by
It should be fine for long term as long as you let it cure. I know techs that use it without issues. It will not effect the wires. Best of luck!
by
Add a comment
Add your answer
erik keating will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,813
