Won't power up - dead
Hi All, I have a Panasonic LUMIX DMC-TZ6 camera that won't power up, I have tried 2 fully charged battery's that work on another camera, taken it apart and cleaned with switch cleaner spray the on-off switch, and sprayed the camera/playback switch,and still no joy, so I presume a fuse has gone inside somewhere ? Anybody know the location of any fuses ? There is a battery under the top cover ML421 that's reading 0.48v is it rechargeable or do I replace it ? Hopefully I will find time later to have another go at it. Cheers Stuart
1 Comment
Hi Tony, Thanks for all of that, don't know the history of the camera as I bought it at a car boot sale (garage sale) I didn't notice any corrosion/water marks inside, like you say its surface mounted components which are a bit more tricky, thanks for the circuit diagram/manual at least I can follow the power track and see where it stops. Cheers Stuart in UK
by Stuart wilson
