The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1529 Questions View all
Won't charge, says This accessory may not be supported.
So here's the story; phone poorly taken apart, damaged chips, managed to get it to work but won't charge. One of the charging ics which I forget the name (9 pins, MOSFET, controls charging) was missing and had 3 ripped pads. Replaced that, now phones recognises charger bit says this accessory may not be supported, before would not recognise it at all. Not showing on pc at all. What should I replace next?
Score 1
Comments:
Hey Giga, I just noticed this question. If you haven't fixed this yet, please let me know which IC exactly you replaced so that I can help you out.
by
Add a comment
Chosen Solution
@refectio i just used the board as a donor, used almost all the parts.
Score 2
Add a comment
Cool, at least you put it to good use.
Score 2
Add a comment
1. Remove any debris from the charging port on the bottom of your device.
2. Restart your iOS device.
3. Try a different USB cable or charger.
4. Make sure that you have the latest version of iOS.
5. Contact Apple Support to set up service.
Comments:
No, read the OPs original post. He took it apart and messed with the internals. It has nothing to do with a dirty charge port or bad cable/charger.
by
Add a comment
Add your answer
Gigabit87898 will be eternally grateful.
Past 24 Hours: 17
Past 7 Days: 124
Past 30 Days: 587
All Time: 36,955
