Factory Y in heater hose
Can I replace this line?
Yes if the line is leaking at the Y then replace the y pipe with another . If its crimped on you may need to cut out the crimping and use gear clamp to replace the Y. Its best to use a metal y but if ones not available to you then plastic can be used as well
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 147
