Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
The ringer is on but the phone won't ring?
I have a 32gb iPhone 3gs. When I first got it the ringer worked fine. Now when I get a call it doesn't ring. I have vibrate on and ringer on. Is there some sort of setting I can change?
Score 1
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
Well, I found out what happened. I inadvertently swithched the ringer off. There is a button right above the volume buttons on the side of the iPhone that controls the mute. I had switched it off my mistake.
Score 10
Comments:
Silly sausage!
by
yes, the mute button was switched off on me as well. must have happened when i cleaned..... thanks to this site
by
Thank you! My phone case doesn't allow for me to see/use that button. I had forgotten it was there. Have been wondering why alarms work, but phone won't ring.
by
You helped me too!!!!
by
Thanks put a new otter box on turned the sound off duh!
by
Show 3 more comments
Add a comment
No1 check is to clean out headphone jack of dirt and fluff. It sometimes tricks the phone into thinking headphones are in!
No2 check settings general sounds
No3 press and hold power and home for 10 sec until apple appears then allow to reboot
No4 replace dock or mic/speaker flex on dock( replacing entire dock is easier)
Score 4
Comments:
Thank you!!!!
by
Add a comment
Wow...too easy! thanks for the help!
Add a comment
I don't have a MUTE button anywhere on my g3 -- ???
Add a comment
Thank you so much, the ringer off button was also off on my phone. I'm a happy camper now. Barbara
Add a comment
Wow. That all that is was for me as well. Thanks!
Add a comment
May 2017 (six years after the original question above) & the answer has just helped us too. Thx so much! We've missed countless calls for months on end because we could not get the phone to ring incoming calls. Cheers from Minden, Ontario Canada (can you hear the rejoicing all the way across the miles? LOL)
Add a comment
Add your answer
Lewis will be eternally grateful.
Past 24 Hours: 12
Past 7 Days: 60
Past 30 Days: 252
All Time: 30,149
