Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 Questions View all
grey screen, non functioning trackpad or keyboard
I originally reviewed this machine with a few keys not functioning, one of those keys being 'R' so booting into recover mode hasn't been an option.
I originally opened this machine to clean the keyboard ribbon connector, I did that, then stripped the rest of the system down to fix a dent without causing harm to any components. I put the system back together and now it only boots to a grey screen.
My only option is booting into safe mode with the 'shift' key or holding the 'option' key then selecting my hard drive. Strangely enough my keyboard works while booting but once the OS is loaded its not functional whats so ever.
Please help, I'm running OS-X El Captain (10.11.6)
1 Comment
Have you tried using a USB keyboard?
by
Add a comment
Chosen Solution
When you boot holding the option key you should then be able to select the recovery drive.
Score 2
1 Comment:
yes i tried that and i attempt to install a new os x onto the drive but it does not complete the install because it can not boot
by
Add a comment
Most Helpful Answer
If you can get into System Preferences, open the keyboard panel take note of the keyboard driver being used and then delete it. Then add it back in so it's refreshed. See if that solves it.
Update (08/29/2017)
Here's where the keyboard drivers are located:
You want to remove the the one on the left then add it back
Score 2
2 Comments:
I'm currently using a usb keyboard and mouse to navigate... but i can't seem to locate where i would see which specific driver is used by the keyboard, i also read somewhere this could be a nvram/pram issue because my fan is constantly running. hope that information can help
by
unfortunately that did not work... although i did find my current internal hdd is failing... could that be a factor in the grey screen issue. i also am able to boot with the option/alt key or option/alt and the d key.
by
Add a comment
Add your answer
marc rollins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 220
