Best SSD blade for my iMac 27 late 2012
Please which SSD blade is the best one, fast and functional for my iMac 27 late 2012 Thank's
There are three different sized blades made by OWC listed on this page for your machine, your choice may be about how deep your pockets are:
@mayer - He wanted the fastest ;-} The OWC blade SSD's are a bit slower. But! they are more readily available.
@danj I've tried to buy a few blades from apple. Bend over and grab your ankles and brace yourself ;=)
@mayer - Yes! Very expensive! The exchange price is better, but you need to be an authorized service center for the discount and it only helps when you are facing a bad one, not adding.
@danj Then most of the ASPs require that they do the installation and that's another $300.
@mayer - Yep! Can't win if you go that route. Best to do a bit of googling to find a junker. As Apple has moved on to a different design in the newest models, we should start seeing some OEM parts hitting the market place.
If you are talking about the PCIe blade SSD Apple uses, you have no choices as Apple uses a custom design.
Apple does not offer it as a replacement part only as an exchange, so you'll need to find one from a parts system.
You might want to think this through as opening the newer 'Thin series' systems are a bear!If you don't use the proper tools and techniques you can damage the display which would be an expensive Opps!
Here is the IFIXIT guide you'll need to follow: iMac Intel 27" EMC 2546 SSD Replacement
If you currently have a Fusion Drive config you'll need to first break the fusion drive set first, following this guide: How to split up a Fusion Drive
If you know wich Apple Blade SSD i should search please give me more information Thank's
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 4,746
