brother mfc J480DW Machine wont power up. Was fine last used.
was working fine then went to use and nothing .Wont turn on.Have tried other power cord .Helpl
Update (08/27/2017)
where do i find out where fuses are
anyone know where i can find the fuses in brother mfc J480DW thanks
Add a comment
1 Answer
Chosen Solution
Here are some steps to ensure proper working order:
  1. Make sure that the outlet it's plugged into is good.
  2. Make sure the power supply is rated for your voltage.
  3. Check for blown fuse.
  4. Ensure any switches are on. Try holding the power button.
  5. Listen very carefully when you plug in the cable. Put your ear up to the power inlet.
If all else fails, please write anything else about it in the comments.
Hope this helps!
Score 1
@leeanne64, did this solve your problem effectively?
Add a comment
Add your answer
Lee-Anne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 35
