Battery won't charge/ Black X on battery icon?
I have a 6 year old 14" ibook G4 1.2ghz that I've managed to keep alive because of your wonderful site. Thank you!
I replaced my old dead battery with a new one from your company recently and the new battery won't take a charge. There is a black "X" on the battery icon.
I've installed a new battery connector, DC-in board, and bought a new power adapter just in case. No change.
The light on the power adapter is always green.
I've heard that the computer might not recognize the battery, but that this could be remedied with a software program.
Do you know anything about this? I would appreciate any suggestions.
Score -1
Add a comment
Chosen Solution
If you haven't already, I'd Google "Coconut Battery", download it, and run it. It will give you some detailed information that might let you determine whether it's the battery or the machine. The power adapter may be showing green because the computer can't charge a bad battery, so if it shows a max MAH capacity of 0, for example, then it's a bad battery. I know your old battery is dead, but when you put it in your machine, does it behave differently, or does it show the same "X"? If it behaves exactly the same, that's evidence that it's the computer (and that your board may be bad, given all you've already replaced), and if it behaves at all differently, that's evidence your new battery is bad.
97% of battery issues, especially with iBooks, turn out to simply be a bad battery. The problem is, most people don't have enough batteries around to do thorough testing. I have found an iBook here and there that was not able to charge a battery due to a problem with the board, but it's pretty rare.
Score 2
Add a comment
this is on the apple support website if that doesnt help you may need to buy a new battery.
or check this forum
Good Luck,
Cody
Add a comment
Add your answer
jeiolson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,337
