Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
installed new screen, turned on once then stopped working
I installed a new screen on my iPhone 7 and when I powered it on it turned on to the the white screen with apple logo and then froze. I tried putting it into recovery mode but it would always go to the same screen and then it stopped working completely. I tried another new screen and it isn't responding at all now. Any ideas?
Score 1
1 Comment:
yeah of course, it started a few times but kept freezing at the white screen with the apple logo and then randomly stopped.
by
Add a comment
This is not good. You may have not installed it correctly and shorted something on the logic board. Did you disconnect the battery before replacing the screen?
Add a comment
Unplug the camera cable and the home button cable from the screen, then plug in the screen and the battery and try powering it on. If it boots fine then, unplug the battery again and try adding the home button, then repeat until you find out which component is causing the problem. If its not booting with just the screen plugged in you have most likely broken something on the logicboard.
Add a comment
Tried disconnecting the camera and home button and still nothing. If something was wrong with the battery would it still turn on if it was plugged in?
1 Comment:
You can try another battery. But Iv never heard of a battery causing a problem when doing a screen. Have you tried plugging in a charge cable ?, Iv seen phones not turn on via the power button before first time after unplugging the battery.
by
Add a comment
Your trying new screens was the original screen working??? If it wasn't and u couldn't see anything then it might have had something wrong with it already if it was working don't try new screens from the same suppliers try the original screen plug it in without the battery connected then once it's securely plugged in plug in the battery
Add a comment
Add your answer
nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 97
