Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
iPhone 7 wont turn on, charge or be recognized by computer
I have Iphone 7 i dropped it screen is damaged, and the iphone now doesnt come on nor will it charge or be recognized by computer when plugged in.
is there anyway to test to see if there is power getting to battery
Score 1
Add a comment
Chosen Solution
If you have access to a USB Ammeter, you could use that to determine if the phone is really drawing current when it is supposed to be charging.
If your phone is not recognized by iTunes, then you probably have a logic board issue. The best way to verify this is to disconnect the screen (LCD & Digitizer), the Front Camera and sensor flex and the upper cable connector. Follow this guide. Then connect it to an iTunes enabled computer. If it is recognized, then add one flex at a time to see what causes the issue.
If it is still not recognized, then you most likely have a logic board issue.
Score 1
3 Comments:
dont have access to a USB Ammeter can you do it using a multi meter
by
Technically yes, but you would have to break open a usb connector and insert your meter in series. It's far simpler and cheaper to buy a USB ammeter.
Otherwise, I recommend you look for a reputable micro-solderer to troubleshoot this issue.
by
thank you for your help will look into the USB ammeter.
by
Add a comment
Have you tried charging it for a bit and then connecting it to a PC? Also, after you charge it try hard resetting it by pressing the power button and volume down for about 10 seconds.
1 Comment:
yes I have tried these still nothing
by
Add a comment
Add your answer
Thomas Hoey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 720
