Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Questions View all
How to Format the Blade SSD on 2013 27" iMac When Upgrading 3TB Drive
I have a 2013 A1419 27" iMac (i5/3.4Ghz) which had a cracked display. I got a replacement in, but it took me a couple of days to realize I also had to move the heat sensor that was on the old display. Prior to that I had been trying everything to get it working properly and the fan not spinning up to full speed with every boot!
One thing I tried was to reformat the Blade SSD attached to the back of the logic board, but now that I know the issue wasn't the SSD drive (yes, I purchases the OWC Inline heat sensor) or the installation of same, I need to format the blade drive on the logic board back to "unformatted" which is what its designation was before.
I've tried Disk Utility, Drive Genius and I've looked at Terminal commands, but do not find a command or item that does what I need. I think possible "writing zeros" in Drive Genius might, but not sure, any "unformatted" formatting thoughts?
Thanks,
JoeL
ATL
2 Comments
Not sure I follow you here.
Normally you would make the SSD your boot drive and then use the SATA drive as your data drive or are you trying to make a Fusion Drive set?
by
Yes, I'm replacing the bad 3TB fusion drive with a 1TB Samsung 850 EVO ssd. But I formatted the on-board Blade SSD and installed the OS, but this person isn't going to want to deal with two drives so I need to UN-format the Blade drive so it can be recognized as the "other" drive (normally the only SSD) in the Fusion Drive set.
Thanks! JoeL
by
Add a comment
1 Answer
Chosen Solution
First you'll need to create a OS installer drive (USB Thumb drive) following this guide: How to create a bootable macOS Sierra installer drive.
Make sure your HD is fully backed up before proceeding.
Booting up with the Installer will allow you to delete any partitions on the SSD using Disk Utility. We don't need to worry about having a GUID partition table.
At this point you'll need to open a terminal session as you'll need to work with CoreStorage at the UNIX command line to bind the two drives together. Here is the guide to recreate the Fusion Drive: How to make your own Fusion Drive.
Now before you do this if you have the original SSD that was part of your original Fusion Drive then go ahead. If you put in your own Apple custom SSD and its larger than 128 GB you might want to leave the system as a two independent drives which will give you the better performance.
In the end its what works for you! Some people like the flat logical volume a Fusion Drive offers.
Score 1
1 Comment:
Worked like a dream! I KNEW you were the guy to ask! Thanks.
JoeL
by
Add a comment
Add your answer
joeldm will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 581
