Repair guides and support for televisions manufactured by Panasonic.
121 Questions View all
Wont turn on..Front L>E>D. flashes 10 times
Panasonic TH-42PZ80U Television
Plug the power to TV the L>E>D> flashes 10 times....pauses then flashes 10 times...keeps repeating.
Ive opened the back cover thought I would try blowing out the dust bunnies..no change.
So I thought I would order a Main Brd. which I did and it hasn't arrived yet. So I was doing more research and Ive found the 2 IC's on 2 separate daughter boards on the Power Supply brd. so I sprayed then with refrigant to freeze them...I did one at a time...and I found one that once I sprayed it..and it was frozen I can power on the TV without any issues...so instead of replacing just that IC and the capistator I thought I would just replace the power board. My concern is on the Power Brd I see a number of NPX702MF-1A and Ive found that part on Ebay but I also see NPX702MF-1 which is a
little less expensive...would that brd work?...or what are the differences?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
@krc9529 you are absolutely right. The 10 Blink code is most commonly related to a failed PSU. The differences in those power boards may just be related to different version/layouts. Always make sure that the connectors are of the same type and in the same location. There are no good schematics out to do a side by side comparison. I would discuss this with the vendor and purchase it if it has a straight forward return policy.
Score 1
Add a comment
Add your answer
gerg45uerf34 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 55
