Repair and disassembly guides for screen doors.
3 Questions View all
Screen door won't close completely without my lifting it into place.
Screen door won't close completely without my lifting the closing pieces into place. Can this be fixed?
Comments:
Thanks ever so much. So nice to have the screen door fixed!
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
This is very common. Usually the door drops. First tighten the upper hinges and see if that pulls it up. If not you may have to put a shim on the lower hinge to push it out. When doing that I would start with an 1/8" shim and try it with the screws out and see if it is enough. If not add another one until it gets aligned.
Score 1
Add a comment
Add your answer
Jane will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 32
