2.3L 4cyl or 3.0L V6, 6th Generation
425 Questions View all
Front left power window does not work,.
2002 honda accord automatic V6 four door .
Front left power window does not work,20A fuse is ok.What to check next? Thanks Ivo
Score 1
1 Comment
Looks like the window was just stuck.Thanks anyways
Ivo
by
Add a comment
1 Answer
Most Helpful Answer
> does not work
Does it try to run? Whirr? Klunk? Or totally silent?
There is a 20A fuse (#15) for the windows, but also a 7.5A fuse #13 for the "multiplex" brain. I'd think a dead multiplex would cause many troubles, but check it anyway.
The switches, relays, and multiplex brain are all-in-one. The factory diagnostic is many pages of tedious tests, and the end result is replace-the-unit.
So check the motor. See attached image from the manual.
If you can hot-wire the into working, but not via the switches, replace the whole door-module. A good auto salvage operation should have these.
This is from the 4cyl 2002 Accord. The V-6 model is different in many ways. You'd think they'd use the same window-motor?
Score 2
1 Comment:
How can I download the manual?
by
Add a comment
Add your answer
tumai will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 13,377
