Clothes dryer repair and support guides.
282 Questions View all
Keeps turning off when starting to dry clothes
When I turn on the GE Electric Dryer DCVH680EJ0WW, it will run for a few minutes and then shut off. What would be causing this? We have tried different heats settings, different type of loads and it happens. Everything else works, plugged in and vent clean.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
We took the vent off and it dryer one load of clothes then when we tried it again, it did the same thing would start and shut off within a few seconds. Going to try and blow it out this evening with air compressor.
Add a comment
Most Helpful Answer
@drweldon sounds like a a faulty thermistor/thermostat. Of course, you also want to try to pull your dryer away from the wall, take off the exhaust vent hose, then run a load with the heated air just going into the room. If it drys good, then the issue is in your vent tubing in your house. You also want to make sure your motor is not clogged up with lint, causing it to overheat and shut down prematurely.
Item number 505 506 and 507 are the parts in question. While I am still trying to find the right tech sheet to assist you in the diagnostics, it might help if you post some of images of your dryen with the back cover removed. For that use this guide Adding images to an existing question
Score 1
Comments:
The diagram you have is it.
by
Add a comment
Add your answer
Donna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 38
All Time: 86
