Microwave won't heat is there a fuse that can be changed ..
== no heat
. My microwave just stopped heating. It turns on but no heat. Is there a fuse that can be replaced?==
Add a comment
1 Answer
Chosen Solution
https://www.repairclinic.com/RepairHelp/...
Cause 1
Diode
The diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron to heat the food. If the diode burns out, the magnetron won’t receive enough voltage to operate, preventing the microwave from heating. When the diode fails, it is often visibly burned out. Inspect the diode and if the diode is burned out, replace it. If inspecting the diode proves inconclusive, test it with a multimeter that uses a 9-volt battery or put a 9-volt battery in series with the diode. When the leads are reversed, the diode should only have continuity in one direction. (Warning: The microwave oven can store a lethal amount of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the high running voltage and the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the diode.)
Parts
Diode for your KenmoreMicrowave
Diode - Part # 1522339 Mfg Part # 6851W1A002E
RepairClinic Item #1522339
Microwave diode assembly
$5.16
Quantity:
In Stock ›
Same Day Shipping
Order by 8:00 PM ET, this part ships TODAY!
365-Day Return Policy
Return any item for any reason within 365 days of placing your order.Find out more »
Total: $5.16
ADD TO CART
Cause 2
Door Switch
Most microwaves have three or four door switches. When the microwave door closes, the door switches actuate in sequence to ensure that the door is closed properly. If any of the door switches fails, the microwave will not start or heat. To determine if any of the door switches are defective, use a multimeter to test each of the switches for continuity. If any of the door switches does not have continuity, replace it. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace a door switch.)
Part Testing
Parts
Door Switch for your KenmoreMicrowave
Door Switch - Part # 1325771 Mfg Part # 3B73362F
RepairClinic Item #1325771
Microwave door switch. This switch is normally open. When the microwave door is shut, the door switches close to send power to the microwave. If this switch fails, the microwave will not start.
$3.85
Quantity:
In Stock ›
Suggested tools
Multi Screwdriver
RepairClinic Item #3527472$14.95
Same Day Shipping
Total: $3.85
ADD TO CART
Cause 3
Magnetron
The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the magnetron burns out, the microwave won’t heat. The magnetron is not repairable—if the magnetron is burned out, you must replace it. (Warning: The microwave oven can store a lethal amount of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the high running voltage and the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the magnetron.)
Parts
Magnetron for your KenmoreMicrowave
Magnetron - Part # 1292196 Mfg Part # 2B71732G
RepairClinic Item #1292196
Magnetron
$108.75
Quantity:
Out of Stock
Click for Expected Ship Date ›
Total: $108.75
ADD TO CART
Add a comment
Add your answer
Sheri Harlan will be eternally grateful.
Past 24 Hours: 32
Past 7 Days: 224
Past 30 Days: 818
All Time: 4,117
