What is the purpose of Q2102 FET on SWI line?
hey
in older iphone models SWI line go directly to Charging IC ,But in Iphone 7 plus there is a kind of FET (Q2102) on SWI line , So what the purpose of this?
hey
I don't have an iPhone 7 on hand to probe the circuit but my reading is as follows:
Why did Apple make this change? Who knows, perhaps they had some data to back up the assertion that some batteries (read: cheapo batteries) were sending spurious signals directly to TIGRIS and causing an unacceptable defect rate. Maybe that was the issue behind the "unexpected shutdown" recall for the iPhone 6S.
So does that mean in iphone 7 model a battery type detection may be integrated?
All TIGRIS enabled devices already had a battery sense line (see pin E1 - BAT_SNS).
Interestingly, the iPhone 6 did not have the FET but rather a direct connection to the battery gauge via a filter (FL2511). Starting with the iPhone 6S, the filter is gone and replaced by an RC Filter configuration, filtering out anything above ~30MHz, and feeding it.
Perhaps even more interesting is that on the iPhone 6S/6S+, the FET is in line with the HDQ_HOST pin of TIGRIS whereas on the iPhone 7/7+, the FET is in line with the HDQ_GAUGE pin. I suspect there is an error on one of the two schematics but unfortunately I don't have an iPhone 7 on hand to check.
So take what I say in my answer with a grain of salt. It makes sense electronically but I can't say for sure if this is indeed the way it's connected on the logic board.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,773
