Shuts off immediately after pressing power on
Hi. I realize there are several issues similar but not quite exact to my problem.
I had used the laptop last friday ok. Powered it off normally. Yesterday I went to turn it on to no avail. What I notice is the front White LED flashes once quickly and that's about it. The battery appears fine as I had been working previously with no problems. The MagSafe led is green and the side green Leds go to full when I press the test button. I've tried tons of things. Resetting the SMC, the NVRAM, re-seating the RAM modules, powering up with battery disconnected, reconnected, etc.
I did notice that when I press the start button, The FAN spins for a second, like the laptop does try to start, but the next second everything is dead. If you press the power on button again, you see the front LED flashing for a split second and the Fan trying to spin. Next second everything is off again.
Help please!
