Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2686 Questions View all
Screen is black after repair but still on. Help?!
So I was repairing a cracked screen on an iphone6s, but before beginning I forgot to shut off the phone, I did disconnect the battery however. Then once I finished the screen is black and won't turn on with the power buttons. It occasionally flashes the screen for a second but then it goes black again. I am able to answer calls and charge it and it is definitely on but it doesn't show dor nor than the rare second. PLEASE HELP ASAP I NEED TO RETURN THE PHONE BY TOMORROW!
1 Comment
I keep extremely good care off which screw goes where so it's definitely not long screw damage.
by
Add a comment
1 Answer
Chosen Solution
The iPhone 6S is prone to backlight circuit issues when the screen is connected with the battery or power on the device.
Have you tried re-installing your original, cracked screen? If that one works, then you have a bad replacement screen. If the original also has the same problem, then you probably blew the backlight circuit somehow.
Score 3
2 Comments:
What do I do if the backlight circuit is blown
by
A blown backlight circuit requires a micro-soldering repair and is not a DIY fix. You will need to tell your customer that there will be a delay and find a reputable shop to do the repair.
by
Add a comment
Add your answer
Nick Genco will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 72
