Did you buy this system used in this state? Or was the system working and stop?
Why I ask is if the SMD part (likely a capacitor or inductor) was either pulled off or the system encountered a failure so it was blown off somehow.
The best thing you can do here is to remove the logic board and do a careful inspection (both sides). If you look on the back of the component you should see the solder tabs, look on the logic board for this fingerprint to locate when it came off. See if the area has any burn marks on the logic board where the SMD was mounted. (take a good picture of the area and post it here for us to see as well).
Your image of the SMD device leads me to believe it was more likely snagged by someone in the process of servicing the system as I don't see any burnt areas or other signs of damage to it.
If there is signs of damage (burnt board or chips) you might have a more expensive repair as you'll likely need a new logic board.
If you don't see any clues on the main logic board or what you can see on the graphics card. The next step is to remove the graphics card. Hopefully this is where it came from where you can't see without first removing.
Here is the IFIXIT guide to follow: Graphics Card replacement This guide is for older 2010 model but is very close to the same process and we don't have a guide for the 2011 model.
Here is the possible graphics cards your system can support:
- AMD Radeon HD 6770, 512 MB VRAM - Apple P/N 661-5967
- AMD Radeon HD 6970, 1 GB VRAM - Apple P/N 661-5968
- AMD Radeon HD 6970, 2 GB VRAM - Apple P/N 661-5969
