Model A1138 / 1440x960 screen resolution
85 Questions View all
What is the best way to copy,delete and reinstall my operating system?
Have been having trouble with O SX crashing, so a suggestion was made to zero out and re-install the operating system. How can I go about copying my files without duplicating possible corrution from the original disc? I have a Firewire external device.Thanks. Mike
Score -1
Add a comment
1 Answer
Chosen Solution
Backup your
data, use install disks to erase and reformat (partition) the HD (Without knowing more about the crashing you may need a new HD if you're having problems).
Once that's done do:
  1. all the OS updates,
  2. copy back the data,
  3. delete all the user/library/preferences, caches
  4. run Applications->Utilities->Disk Utility->Disk First Aid:Repair Permissions before using (many problems can be caused by corrupt .plist and cache files.)
Remember to return and mark as accepted the answer that best solves your problem.
Good luck,
N
Score 1
2 Comments:
Here is the link to Apples guide to reinstall Snow Leopard but the basics are the same.
http://support.apple.com/kb/HT3910?viewl...
by
Thanks for that info. I am leaning towards replacing the drive.
by
Add a comment
Add your answer
Michael McGuire will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 858
