Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
Broken Digitizer ribbon. What now?
So, I took apart my iPhone 4 using an iFixit guide to get to the home button to fix an issue with that (I just needed to clean around it). I accomplished that, but while I was reassembling it, the end of the digitizer cable snapped off.
Do I have to replace the entire display assembly now? Is there another option because I don't really want to spend $150 to fix this...
Add a comment
Chosen Solution
Thanks. I hate to admit this, but I actually closed up the phone and took it to Apple and said that the touchscreen just stopped responding. After determining it was a hardware issue (I just played dumb and didn't say anything), they swapped it out...
Add a comment
yeah you would have to purchase another display assembly. unless you're a very professional technician that can fix tiny ribbon cables.
i had the same problem as you did, and had to purchase another assembly...
Add a comment
Did apple try and repair the phone first, or did they just replace it?
Add a comment
Add your answer
ben will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 6,158
