Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1958 Questions View all
My iPhone doesn't switch on and doesn't recognized from iTunes.
Hi,
I have made two dumb error trying to replace the LDC dispaly in my iPhone.
Firstly I don't have took care about the two different type of LCD display installed on the two different devices, so I've istalled my good LCD display of my old iPhone 3G in my new 3GS with the broken dispaly! Good idea... now I have burned out the coil of my 3GS iPhone (the backlight of the LCD didn't work!).
After that, just because it was not enough, I try to clean the 3rd pin of the connector number 1 before trying to soldering the wire from the coil to the 3rd pin but while cleaning I have seen that one of the other pins was a little bit bent so, I'm really a genius, I have took a pricker to straighten out it and looks... a sparklet from the pricker to the pin!
I'm not sure if the sparklet was for the static charge or the contact from two different pin. Truth to tell the sparklet was very small and I'm not sure that happened but anyway after that the iPhone doesn't switch on, doesn't charge and doesn't recognized from iTunes!
Now my questions are:
1 - Have someone some idea to fix the problem?
2 - What is possible happened on logic board?
3 - Is possible try to check the voltages in some point to understand how much is the seriousness of the situation?
Any help would be greatly appreciated.
Sorry for my terrible English
Score 1
Add a comment
Most Helpful Answer
Sorry to hear about your problems.
I think what happened has to do with the change from the 3g screen to the 3gs phone. I think you've shorted out the board with that, not with the fiddling with the Connector 1. There are some solutions I've seen online that dealt with replacing the coil, or jumping to pin 3 from one of the board components. (I'll see if I can get you those links.)
I don't know what your soldering skills or tools are like, but it may be that you'll need to do some finely detailed work to follow those links. Failing that, I think you need a new board.
I had a similar problem Sleep/Wake Button Doesn't turn off phone - Liquid Damage, and was unable to resolve it, but I hope yours works out.
Score 3
Comments:
here are those links i mentioned (3g maybe)
http://www.rapidrepair.com/phpbb/viewtop...
and http://blog.techsick.com/guides-tutorial... (server was down earlier)
by
Add a comment
[url=http://phonepartsusa.com/apple-iphone/ip...]iphone 3g white screen[/url]
Add a comment
I've found a related guide for you.
How to Backup iPhone when iTunes Doesn’t Recognize iPhone
Add a comment
Add your answer
Gianluca will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,343
