Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Screen flickering on replacement screen (original work fine)
While looking into answers on ifixit i found this video : https://youtu.be/m8bLkwm9hJc in this post : iPhone 6 - irregular backlight flickering
It shows the same problem i am having with a few differences.
1. it happens all the time, no 50/50 chance of it happening like the guy in the other post said.
2. it does not happen with the original cracked screen, with it all is working fine.
i have changed the battery and have tried with 5 different screens, all have the same problem, some flicker more than others though. what is strange to me is that whenever i change back to the original screen there is no problems.
anyone know what is up with this ?
1 Comment
i have now tried several screens. with one of the replacement screens it works 4/5 time i wake the screen, the 5th it will flicker like with the others. so i tried to use another broken screen i had, this one is apple original, no problems with it either. so it appears that for some reason this phone reject any non apple screen !?
by
Add a comment
1 Answer
Chosen Solution
I'm not sure why it's not happening with the original screen and it's happening with the other new screens, but it does sound like a backlight coil or a backlight diode or the backlight IC is going out, does it make a difference if you go into settings and turn the brightness of your screen up?
Score 3
1 Comment:
I dont think i will be able to change these, as i understand this requires microsoldering which i have yet to learn.
was hoping there would be something i could do without it, since it work perfect with the original screen 100% of the time, so if anyone could shine some light on why this happens it would be much appreciated.
by
Add a comment
Add your answer
KCtech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 197
