Wash ,Rinsing and Draining okay but not Spinning Cycle working
I have a Kenmore 90 Series Washer (110-C28922790). Washing , rinsing and draining no problem. But when it came to the spinning cycle doesn't spin. I need to start spinning manually until it start spinning and depress the timer off and turn it to spin cycle to turn it on at same time (doing this step few time) manually spin it. Eventually it will start spinning to its full speed. I checked the coupling had no problem and the agitator little worn but will replace it. Can you tell me wants the problem. Thank you
Add a comment
1 Answer
Chosen Solution
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Score 1
Add a comment
Add your answer
John Jang will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 278
