Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
233 Questions View all
Updates HD with Same Manufacture and got the Loud Fan?
My iMac came with Western Digital, wd1001fals (1TB), I just tried to update the hard drive and install a western digital WD2001FASS (2TB) Drive. They both have the same connections on it. I put the Thermal cable on it same way it was on the Original Drive. Even so I got the Really Loud Fan Situation with the new drive. When I went back to the old drive it went away.
Can you use the WD2001FASS on the imac? or do i have to hook it up diffrently?
Please help for I am lost on this one.
Thanks in advance
Add a comment
1 Answer
Chosen Solution
The new 2tb HDD could be putting out more heat and thus the sensor picks up the higher temperature reading and tells the HD fans to spin faster. These hard drives are fully compatible with Macs so that is not the problem.
The 2TB one has dual actuators while the 1TB has single and also the 2TB has 64MB Cache while the other has 32MB. These differences in performance and extra moving parts can make a difference in how much heat output the drive has even if they are the same manufacturer and line.
Make sure you put the sensor on the same exact spot. If the fan speeds are faster then I really wouldn't worry about it as long as you keep an eye out on your temperatures. Install iStat Pro widget so you can see if there are temperature differences between the 2 drives: iStat Pro
If the louder fans really do bother you then you can spend about $30.00 more on the 3TB WD Caviar Green WD30EZRSDTL. The Caviar Green line runs cooler and it has less power consumption than the Caviar Black. The 3TB drive has the same specs as your 2TB but it has IntelliPower technology which lowers the RPM when not in use thus reducing temperatures.
http://www.wdc.com/en/products/products....
http://www.newegg.com/Product/Product.as...
Add a comment
Add your answer
Scott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,344
