Repair information and guides for MacBook Pro models with 13" displays.
9740 Questions View all
Why doesn't camera work after glass cover repair
I replaced my glass LCD cover after the glass cracked. The LCD and camera were all working fine despite the crack in the glass. After removing the glass cover, I turned the computer on before replacing the new glass cover. The built-in camera no longer appears to work. Could this be a plug on the cable that goes to the camera?
Score -1
Add a comment
1 Answer
Chosen Solution
Sounds like you accidentally unplugged the cable or one of the connections is loose or not connected all the way. I have seen many MacBook Pro unibodies with hinge problems and sometimes the hinges cut the mic and isight cables. I would take it back apart to see if you can find out what is wrong.
Add a comment
Add your answer
Eric will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,269
