charging port when connected won't let the phone turn on. why?
Hello,
i have a galaxy s7 that got some water damage, i cleaned the entire motherboard with alcohol and put it all back to gather. i tried to power on the phone but it was stuck in a boot loop. i tried all of the normal software things like deleting the cash and even restoring the phone to factory settings. still in a boot loop. then it accoured to me that the damage was located where the motherboard is connected to the daughter board. so i disconnected the daughter board and it started up like normal. so i know the speaker does not work and the headphone jack as well is dead along with the back button and menu button. but the charging port still works. i can only reconnect the daughter board once the phone is turned on, if the phone powers off it will not turn back on without the daughter board being disconnected. so my question is , is there a connection with the mother and daughter boards that would cause a boot loop, and if so what is causing it? would it just be a fuse that is blown on the motherboard or is it the entire daughter board that needs to be replaced. if anyone can help i would be grateful.
