Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1002 Questions View all
New screen, temperature error
I just replaced the cracked screen using ifixit complete screen kit, went great, however, now when it powers up I am getting a Temperature and Thermometer graphic on the phone? Any ideas?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Do you mean this one, the one with the front camera and sensors pre-installed?
Sometimes you get poor quality replacement small parts on these all-included screen assemblies. They can cause excessive current draws, which would manifest itself by shorter battery life or excessive heat. You can test for this by disconnecting the Front Camera & Sensor Flex to see if the problem goes away. If it is bad parts, contact iFixit support and they will make things right. (You can also put back your old screen to see...just don't forget to disconnect the battery first!)
IMHO, it's always better to retain as many Apple original parts as possible. It's more work but you have better components. Aftermarket Small Parts, such as cameras and whatnot, have a tendency to be low (or lower) quality.
iPhone 6s LCD Screen and Digitizer Full Assembly  Image
Score 2
Comments:
Hello, and thank you, I will try to remove as many parts from the cracked screen and see if the error clears. THank you!
by
Add a comment
Add your answer
chuck lear will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 30
