Do I have an inboard DC magsafe issue
I have an early 2011 Apple MacBook Pro 15". Battery is good but was having problems with power adapter running hot when charging while machine was turned on or at sleep. If shutdown then charging would occur normally and charger stayed cool.
Today when I plugged in machine while working the magsafe light on adapter stays green (never turns orange) to charge. Will not charge when shut down either.
Tried second power adapter same result. Early symptom indicated bad inboard DC magsafe unit but not sure now that it will not charge at all.
2 Comments
Thanks so much for the response.
Here is the coconut battery screenshot.
[image|1169087]
Could not grab the secondary screen but it says the battery is good but then on line with battery failure it says yes.
by randallthursby
Drats image failed
by randallthursby
