Why is my battery getting so hot its shuttin device down after a new
Bought a new battrty installed it now it gets super hot shuts off and doesnt hold a charge
Hi Deb. My initial thought is that the soldering of the battery connectors may not have been successful. Too much heat applied could damage the battery flex cable (causing a partial short) or damaging the logic board.
I would open up the device and do a thorough visual inspection of the battery connector area.
It is also possible that you received a bad battery. If you are confident in your soldering skills, then you could put back the old battery to see if the excess heats goes away.
Thank you i will check it out
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 48
