Showing no sign of life
Hi Guys.
OK never seen this before.
Client brought this in won't start up so first thing to try is battery but it would seem thats not the issue
So i open it up & see if there are any signs of liquid damage ETC disconnected battery connected to power tried to start it up.
None of this worked so i reconnected the battery & connected to power the fans started spinning.
Took it off the battery with just magsafe nothing just connected to battery nothing but when connected to both the fans spin up Mac still doesn't boot.
Before i start searching the issue down as this could be time consuming has anyone come across this before & did you get a resolution?
Yes i'm being cheeky I'm going on holiday on weds so time is tight.
Thank you in advance
1 Comment
Hi Reece.
Thank you for your help.
No theres no clicking or i can't hear anything.
I have had some progress I came in this morning it is powering on as the fans spin up either on the power or the battery however if i disconnect the battery then reconnect it does power on & i can log in but it won't when the magsafe is connected but if you reboot it goes back to just the fans spinning up.
by Kenny Leonard
