iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
391 Questions View all
Ripped two contact Pads while desoldering pins from bad LVDS Connector
Hello,
As said in the title, I was trying to remove a damaged lvds connector to solder a new one and had a hard time desoldering pins, probably due to a combinaition of my poor soldering skills and cheap solder iron (first time trying this kind of repair).
Anyway I have no idea how to go about fixing this now.
I suppose I'll have to make some kind of copper jumper but I am clueless about that.
Any advice ?
Is my board ruined ?
Thanks in advance
Score 1
Add a comment
1 Answer
Chosen Solution
I could spend a while typing out what to do but this site is quit good and you should get the jist from it . http://www.instructables.com/id/Repairin... these videos are also well done
https://www.youtube.com/watch?v=mAG0Wk-l...
https://www.youtube.com/watch?v=Mba1fnQc...
Part 1 and 2 . In the future when removing anything with multiple solder points its best to use a heat station to get even heat over the entire area and lift evenly never pry. Use Kapton tape to protect the surrounding areas. Hope this helps
Score 4
Comments:
Thanks alot !
I can now see that this is beyond my skill level to fix as I do not have the appropriate tools and knowledge. The traces are microscopic and I can't even see which trace goes to which pad with my magnifying glass so I can't only guess how to solder a pad to a probe.
Thanks anyway :)
As for the heat station, I have one and tryied to heat up the connector but the pad was getting desoldered before the lead points of the pins starting from 220 celcius :/
by
Not giving up ! Found board schematics ( 820-2733-A ) and boardview file and found where I have to solder my jumpers. Can I fix it ? :D
by
Add a comment
Add your answer
Zdaar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 102
