The Toyota Camry is an automobile sold internationally by the Japanese manufacturer Toyota since 1982, spanning multiple generations. Originally compact in size (narrow-body), later Camry models have grown to fit the mid-size classification (wide-body)—although the two sizes co-existed in the 1990s.
127 Questions View all
Why the car is consuming more fuel
The car showing no other symptoms.but the fuel consumption is double than usual.
Add a comment
1 Answer
Chosen Solution
A more detailed question should be asked. What type of engine. Is the check engine light on. When is the last time you had a tuneup? My guess is never...
Double the fuel consumption you either have drag (issue with the brake system, seized calipers), sensor(s), fouled plugs, air filter clogged, vacuum leaks, a fuel leak, under inflated tires. Although it won't be a tire issue..
My guess is start with a tuneup, plugs, filter etc..
Add a comment
Add your answer
alimoosagarage will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 38
