Repair manuals for over two decades of Mac Laptops—iBook, PowerBook, MacBook, MacBook Pro, and MacBook Air.
30489 Questions View all
replacement of flat cables
hi,
i have issues with reconnecting this two flatcables back to their socket.
i get them into it for... well 1/3 of the Way but then i have no more grip/power to push them further.
anybody got a trick how to reconnect them totally without damaging them?
thanks folks
Add a comment
1 Answer
Most Helpful Answer
I use electricians black tape! I cut a strip as wide as the cable, fold the end over to make a pull tab. Then placing it on the top side of the ribbon just below the connection it gives me a very easy way to ease the ribbon into place.
Don't forget to make sure the connectors slide bar is in the relaxed state and you didn't pull it off either which is quite easy to do!
Once in place the tape is easy to pull off as the adhesive is not too strong.
Score 3
4 Comments:
A masters tip ;-)
by
thats it, tanks.
can you tell me what are these cables for?
by
Well this fixed it, tank you Dan !
But the Problem (MacBook isnt able to charge the Battery anymore) still exist. :-(
I had already replaced the Battery, the external AC-Adapter and now the Internal DC-Adapter.
Semms to be a Problem with the Logic Board - but at least i tried to fix it .... :-(
by
Sorry to here after all of the effort your logic board has a problem,
by
Add a comment
Add your answer
Baumgardt1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 46
