The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3363 Questions View all
Why does my phone say "charging" when my battery goes down?
I've replaced my battery a few weeks ago because when I drained it's battery , it won't open after 1 day of charging. But then , i've been facing this problem lately , there's a lightning symbol that indicates that it's charging , but when I checked for a few times , the battery percent goes down. And earlier , I unplugged the cord of my charger , it was about 60% , then the lightning symbol was still there , it took about atleast 10 seconds before it was gone.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Replacing the battery was the smart thing to do as given the age of the phone, it was most likely at the end of it's life.
There is a possibility that your replacement battery is defective; there are lots of low quality batteries on the aftermarket. However, your phone appears to be suffering from fake charging. This is most likely a bad U2(Tristar) IC on the logic board. This requires a micro-soldering repair and is not a DIY fix. Your best bet is to find an experienced micro-solderer.
If you want to continue to do some diagnostics, you could try the following:
  • If you have access to another, preferably known-good battery, then you could try that one.
  • Is your phone recognized by iTunes and can you complete a backup or Sync of your phone? Not being able to do so would also point to a Tristar problem.
  • Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). It will tell you what the health of the battery is. If the software won't give you any details about the battery, it once again points towards a logic board issue.
  • If you have access to a USB Ammeter, you could use that to determine if the phone is really drawing current when it says it's charging.
  • Do a thorough visual inspection, preferably with magnification, of the area surrounding the battery connector. There are several tiny SMD components just above the connector. Of particular importance is FL11, at the top-left of the connector. If it is missing (which can happen when you pry the connector off), then the battery state does not get communicated to the CPU and this can also cause charging issues and fluctuating readings.
Score 2
Add a comment
Add your answer
Weird Unipotato will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 45
