White smoke and higher speed when warm Briggs & Stratton
So I purchased a second hand lawn mower with a B&S 10T802 engine.
The previous owner already informed me that the lawn mower had been severely overfilled with oil once and ran for a while. It was drained for oil and cleaned up by a service shop, but next season it did not run anymore.
I got it running when I got it by cleaning the carburettor and everything seemed nice, but after 5-10 minutes it starts emitting white smoke from the exhaust and it runs at a much higher speed than when cool.
I understand white smoke means oil burning, so I`ve checked the crankcase breather valve and tube.
So my next thought is the piston rings or head gasket, but why would these break due to overfilling?
Also I cannot understand why broken head gasket will cause white smoke.
It does not seem to lack any power and it starts at first pull after primed.
Any help would be much appreciated.
3 Comments
@mrlaurel how long did you run it? Any change in exhaust color? what did the plug face look like? Grey, brown, black etc?
by
When it is cool there are no visible smoke, only a strong smell which hurts a bit in th nose. When warm it is only white smoke, and still the smell.
There are visible oil around the exhaust so I'm quite sure it is oil burning.
Spark plug is black and oily wet with some debris/buildup. I've cleaned it and also replaced it, but the oily wet returns after a few minutes.
Btw, oil has been changed and gasoline is new.
by
No one that can help me with this one? Winter is coming and I wanted an off season repair project.
by
Add a comment
Most Helpful Answer
Take a look at this answer as this can be several different things, Also drain the gas before winter, I also drain the oil, change the air filter, check the vent on the gas cap and start fresh next year.
I put new oil in my Lawn Mower now it smoking white
Score 2
Add a comment
Overhead valve sleeves guides have been known to come loose and cause oil in piston chamber causing smoke
Add a comment
Add your answer
Kenneth will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 2,049
